For the JoomlArt Advanced Custom Modules in this template, when creating a new language that is RTL, will the text entered into the custom module fields be aligned to the right instead of aligned to the left?
Hi Yes the ACM has the RTL CSS already. Make sure you have enabled the RTL option from the Template style options. So it will work all over the site where this template is used.
