Iโ€™m trying to add social remarketing/conversion tracking just before the </body> closing tag. I am using the Buildr template and have place the code in the Template Styles under the Settings tab. The code is for Twitter and Linked In. It is showing but not right before the </body> closing tag, there are other bits of scripting shown after it. Neither scripts are working as they should and Iโ€™m wondering if the fact itโ€™s not directly before </body> tag is the reason why. Is there a way to switch the order and ensure that the conversion tracking right underneath everything else?
Many thanks in advance for your help.
Best wishes
Heather
    heather-king You can also enter the script manually in /templates/buildr/tpls/default.php before </body> tag
    Also, Some of tips provided here could be of help ๐Ÿ™‚
    Does the script work when Default Joomla Template is assigned ?
    If it doesnt still work, Can you add your admin and ftp details in edit fields in order for us to take closer look although I can see the script reference through page source
    For reference, You can follow thread post (5 point) procedure.
    Thank you very much. I have edited the default.php and Twitter is now working. We're still waiting to see if Linked In activates, if there's anymore problems I'll get back to you.
    Thanks you again.
    Best wishes
      heather-king We're still waiting to see if Linked In activates, if there's anymore problems I'll get back to you.
      Sure, We look forward to hear back in case further assistance required with the parent topic or moving the topic to resolved ๐Ÿ™‚
