Hi guys.
I have question about low quality thumbnails listed on the front page - how can I improve it?
is it script issue (code?) or maybe something different ?
/WP theme/
Low quality thumbnails
As I remember you can set thumbnail size in theme settings (Appearance -> Customize section)
Could you add your website backend access to this thread fields? I'll be able to help then..
Cheers
Joshua
Hi Joshua
I checked all template settings and this
it's not the size setting issue but the quality of the image after resizing.
I've made thumbs a little bigger than standard and the quality drop down like hell.
So I'm looking for solution for increasing the image quality for the current size.
Instead 300x300 i used 450x320 and the images are blury when I downsize to 300x300 all looks great ... so I guess it's css but I can't find it.
