Could you please update this thread fields with your site back-end access (user, password) and FTP (host, user, password). These fields are visible for moderators only.
https://cl.ly/3y3R0p24250G
Then we'll be able to check the issue.
Cheers
Joshua
theAnt Hi. I'm afraid NSP is only capable to pick up a resource from one language at a time. You will need to make a copy of NSP per language, publish it in the same module position but each one of them will need to be assigned to a different language. Additionally to force NSP to show a content from correct language You will need to configure corespondent copy while using a language in joomla panel which You actually need for NSP.
I know it's a troublesome workaround, but I do not think a plugin for falang-nsp support been released ever. Also cannot find it on the net as well.
    The difference between the two sites is that the first one (where the module doesn't work) uses Advanced Module Manager to assign the module.
    Anyway, the module worked well until a few days ago. I don't know has changed now. The only update I did was Joomla 3.8.12 to .13
    teitbite
    It seems the problem is on the module version.
    In your blog I see that a 1.9.7 version has been released, but in download page only a 1.9.4 version is available.
    In the past I downloaded a 1.9.6 version...
    From a backup I see that the NSP version that works with Falang and Advanced Module Manager (on my site) was the 1.9.3.8
    this is the demonstration that NSP GK5, Advanced Module Manager and Falang can work fine together.
    Please, Is available a 1.9.3.8 module version installer?
    Is it possible for you to check and found what causes the issue into latest versions?
    Thanks a lot
    theAnt Hi, unfortunately I do not have that version, but changes between them was mearly cosmetic and some minor adjustments, nothing which could cause such issue.
    But I remember talking to Peter who is AMM developer about problem with NSP and indeed in some cases he was suggesting to disable using Advanced Module Manager and configure NSP while using joomla's module manager. I know it will not allow those cool options, but it's worth trying.
    Anyway I'm pretty sure it's a problem with language, but please exclude the thing I've just mentioned first.
      teitbite
      thanks anyway, I found the 1.9.3.8 on the Github page. But the problem is not the NSP GK5 version.
      At last, the only difference I found between the pages where the module works fine and where not, is the page url.
      It works fine in translated pages with links like:
      index.php?option=com_content&view=category&layout=blog&id=14&filter_tag[0]=&Itemid=519&lang=en
      it doesn't works with links like:
      index.php?option=com_content&view=category&layout=blog&id=16&Itemid=572&lang=en
      so probably the problem is about "&filter_tag[0]=”
      but I don't know, I have no idea what it is.
      Just to inform who has the same problem: after translated correctly all (menu, categories, contents and added the intro image in every translated article, put into the correct order language filter and falang database drive plugins) NSP GK5 and Falang work fine together.
