Top Ad Not Showed Module Position Error?
Multi-Language Coming How to Fix This Problem
Hi medator
I published your banner module ( configured in the correct way ) in acm-topbar position and it works fine now -
Thank you federation Problem?
Apply Module Position to Other Templates
Name: Opening but lost under menu
medator
It is due to the fixed position for the sticky mainmenu you added
Remove it as it is in uber demo and it will works fine.
I Below will delete the code Will I edit it?
[root] / templates / Uber Template / css / template.css
.t3-header.affix { position: fixed; top: 0; left: 0; right: 0; }
Sticky Menu As This Page
The Adhesive Menu Will Stay The Same As It Is On The Joomlart Site
Sticky Menu Will Not Be Lost When I Pull The Page To The Lower Side Menu as Sticky
Ad Module Scrolled Image Down When I Set As Sticky Menu
It's normal at boot but next time it looks down on the bottom side
View This Page
You should remove the code
.t3-header.affix { position:fixed
