Hello, I have two problems with this site that maybe related so I will add them together if that's OK. First up, when I try to configure the mega menu, I get a message 'loading menu' then nothing happens. The mega menu does not appear as it normally does for setup and customisation. The second issue is the two ACM modules I have created in the spotlight-tp-1 position will not load. I have even allocated them to All Pages but nothing works. My suspicion is if the mega menu problem is fixed, it might have something to do with the second issue. Any help would be appreciated. Regards, JR
Hi, I have solved the problem of the two ACM modules not loading in the spotlight-tp-1 position.
I'm still having issues with the mega menu not loading.
Can you help with some advice how to fix this? Thanks, JR
jross Hi The megamenu URL is blocked by Admin tool component installed on you site, it does not allow /damec/?t3action=megamenu&t3task=display&styleid=13&template=ja_alumni&t3menu=mainmenu&t3acl=1&t3lang=*&rand=0.4011913597024177 URL to load. http://prntscr.com/lky9bp Kindly check the configuration of Admin tool and allow the URL to load. It will fix the issue.
Thank you for that. I'll try and disable it JR
