The slideshow in the ja_healthcare template is running too fast and cannot be controlled anywhere. Prior posts pointed to the "autoplay" parameter in the style-owl.php file to be set to the delay in ms - this does not work.
It is set to 432112 and flies through the slides at the same speed it was at any setting in the menu.
How can this be fixed? (it is about the ACM stepchild that nobody at joomlart wants to support...)
Kindly apply the suggestion given in this post to adjust the slideshow speed.
Hope it helps.
