Highlighter GK5 (Joomla 3.9). Animation speed for Infinite scroller is too fast. I set speed to 700000 ms but animation does not become slower?
Kind regards, Klaus
brause
You can share the credentials of your site so I can check: https://cl.ly/3y3R0p24250G
I edit fields for admin and ftp access.
Still another question: how can I delete the colon of the title?
problem solved
brause Hi. Do You mean the problem with infinite scroller speed or the colon? Could You please share the solution in case other users will be looking for the same fix?
Hello I have the same problem. How did you resolve? Can we learn it? Thanks
muratyil Did you try to change the speed in the module settings?
If it doesn't affect, you can create a new discussion and share us the login info so we can take a look.
