I use the extension invoice manager from joomlathat . The front end is not displaying as it should. It works with other templates. Go to administrator > invoice manager > invoices > click on a name -- to show a template then click the public link button. Here is a sample link:
siteURL/index.php?option=com_invoices&view=invoice&id=16&auth_code=oPc28PfcbyAfmVYNmjoWSCHxXEkU8j6elMBnWpW5CVFnPWGn9GhAN2ktJrknsWTf
charlessteiner Hi Can you share the URL of site on which you have this problem. When i am trying to open the submitted site URL its redirecting me to https://box.organizedcompanies.net/ and showing this page : http://prntscr.com/lwssu5
There was some problem with DNS, I think I fixed it by resubmitting record.
give it a try now. It should work now.
If it does not try to prefix it with www.
thanks
charlessteiner Hi The issue is in the template style layout. You are using Onepage layout in the default template, and the link use default template of site http://prntscr.com/lx9n5e There is no content block to show data in this layout. Kindly change the layout to default. And for all other homepages you can use a different onepage template style and assign that to menu items for onepage layout.
Thanks for the help, Pankaj.
