Dear Sir/ Madam
I have some problems with my website: i used Utafiti template from JoomBamboo (https://www.joomlabamboo.com/joomla-templates/utafiti) for my website
I also used K2 extension in this website. I have setup K2 template in my website but when I click Media Manager in K2 extension, ot have some problems, this is a blank page. You can check photo which attach this email
Can you help me fix it ?
Best regards
Ryan
    Hi saguaros
    Thank for your information
    It happen when I install K2 component in my website. I can still access K2 articles or K2 Categories . But K2 media Manager have this problem.
    Thank you
    Best regards
    Ryan
      hovantaibk98 Hi. I'm afraid this is something with K2, so You will have to contact K2 support. None of our extensions has an effect on joomla panel.
        Hi teitbite
        I have fixed it . Lastest K2 version is not suitable for our website. I have changed earlier K2 version and this problem was solved
        Best regards
        Ryan
