Hi - I'm having a problem with buildr template left-main-right.
When I go to Templates: edit styles > layout The layout panel is blank, and shows the default stored layout as allpositions.
If I load this layout and save, it alters the layout on the front end.
A long time ago I renamed the layout I was working with as SIB - but if I load this one the front end changes as well, which I don't want.
I've tried loading several other layouts, all of which have the same effect.
Clearly in the past I have got something wrong, but I can't see what.
The current front end is fine. Is there any way of seeing which version of the template I'm actually using, and getting it to load as the default?
Ian
