Hi there,
I have problems with the mobile menu in offcanvas setting - I use the buildr template, offcanvas is enabled (see screenshot No 1)
The problem is, that the trigger moment for the regular nav collapse at 1280px (see No. 2) works fine and offcanvas maximum width visible is set to nav collapse also (see No. 3), but the mobile menu appears only at screensize of 978px and below (see No 4). Between 979px (see No. 5) and 1280px and higher I have no navigation on my site.
Any idea?
Thanks for help, Orti
