hi again!
I want to use the GKtab module in the EMPRESA page of my website. I have created the tab module without problem.
I have two options to place it: in the sidebar or in the bottom.
If I place the module in the bottom_1 I have 2 issues, the witdh of text module is wider and is very far from the main body as you can see in the screenshot.
The siderbar position is disabled as I can read in the module variations page:
"Full width for the content can be achieved with the full-width suffix. The more narrow layout can be achieved with the narrow-width suffix. On pages where full-width is a default mode (K2 and com_content subpages) you can disable full width using the no-full-width suffix."
As the page is a joomla article, how can I use the suffix? in the tab module I can´t use a suffix either.
    Ok, that worked!
    but, can you tell me what can I do to place the module in the siderbar position? thanks
      roberbond
      You can publish the module on sidebar position.
      Module needs a position to show it on frontend, if position is correct it will show fine.
        Ninja I know that. But the sidebar position is disabled. If you read the module variation page it says: "The sidebar module position is not available on the com_content and K2 subpages without no-full-width suffix. Additonally this module position is disabled on every subpage with the full-width page suffix. The breadcrumb module position is not displayed on the K2 and com_content single item subpages."
        Where can I add the suffixs?
          roberbond Hi,
          You may try replace the file attached (unzipped) with the current one in folder : \templates\gk_photo\layouts however do ensure to take backup of your site and current file, precisely, before performing aforesaid steps, in case rollback required whilst facing any issues e.t.c
          Thereafter, try assigning your module to sidebar module position for it to reflect
          Also, Kindly presume this to be temporary workaround
          Have reported the same with JA Dev. Team as sidebar isnt appearing due to conditional statements and we should have more concrete fix with upcoming version releases
          Cheers
          default.zip
          3kB
          14 days later
          roberbond Hi
          You may download and update to latest version i.e.3.29 as JA Dev. Team has fixed the relative bugs including this one, reported with the latest version release 🙂
          Would suggest to take backup of your site before performing aforesaid steps, in case rollback required whilst facing any issues e.t.c
          roberbond
          The team release a new version for GK Photo on 8 Apr, you can take a backup of your site and update this latest version.
          hi! I have updated to the last version for GK Photo ver.3.29 and is not working.
            roberbond Hi
            Can you add your admin and ftp details in edit fields in order for us to take closer look.
            For reference, You can follow thread post (5 point) procedure.
            Also, In furtherance, Kindly let us the know the specific modules type and title/ID which you have published and assigned to sidebar module position
