Hi defall
Could you edit your first post and add to it your website url ?
To restore your topbar-left icon edit your module named info and add to it this code
<span class="fa fa-map-marker" aria-hidden="true"></span> 655 Auer Garden Apt. 026, Wolffport
Since it is a csutom module you should first disable from global settings your default editor setting it to None , in this way html code will be not stripped when module is saved.
