When I switch the language, the menu remains in the previous language (until I refresh the page). How do you fix it so that the menu changes the language immediately??
chicku Hi I need to check this issue n your site, Kindly provide a temp super user login details and steps to replicate this issue on your site. Submit the information via Edit fields option in first post.
OK
chicku Kindly review as the site url isnt opening henceforth inaccessible. Ref: Screenshot
Site is: http://chick3.nstrefa.pl/jaroslaw (not chick3.nstrefa.pl)
do you know how this can be solved?
chicku Hi The site is not accessible : http://prntscr.com/njag1g Kindly check and unblock the site access for India, Vietnam and italy.
Try again from https://chick3.nstrefa.pl/jaroslaw/pl/
chicku Hi You need to turn off the Ajax from template style option to load the page from a new Language. I turned it off, kindly check the site now.
