Hi, i am not sure where to add custom code... I tried in backend - template - Add Custom Code and before head, after head... body didnt work also.
Now i put this into the template.css file and this works... but is it the right place?
edit: Think i worked this out. I made a file named custom.css and put the code there. That worked!
Thanks anyway for your help!
Gr. Dragos
