Hi, I have a problem with module: News Show Pro GK5 mode: TechNews I. The module is displayed on the main page correctly, unfortunately, links to linked articles do not work. Best Regards, Mateusz
Hi mhorodecki
You will need to find correct layout for your module, not all layouts types has link to articles as you need. Try to change layouts settings and test the one that suite your needs.
Hope it helps
pavit Hello Pavit.
I am a bit surprised by this. I expected that the module will work with all available templates and does not work with the template from the same team.
Thank you for answer.
I was referring to the module settings for layouts, nothing to do with the template layout
http://prntscr.com/nxd9rw
