I am using the Joomlabamboo Grid4 template. I am having trouble modifying the overlay for theZentools slideshow module in the background position. Nothing I change in the theme tab seems to have any effect. My website is http://www.civanowebdesign.com/ The overlay is much darker than I would like. (I re-used the module from the demo.)
Thank you, Charles
Hi Charles,
Can you add login details so I can take a look?
Thanks Paul
Good to hear from you again Paul.
Login details: removed
Thanks for taking a look
Hi 🙂
I just removed your details
Can you add them via step 5 and I will look in the morning as 2am here
https://member.joomlart.com/forums/d/772-how-to-ask-a-question-on-forum
Hi Paul,
Thanks for helping me keep out of trouble.
I put the credentials in the correct place (the black box) this time.
No worries Charles on the access details 🙂 I don't think they were up long before I deleted them
Back to the question
If you open the settings under the style tab (right column of the settings at the top) there is a section called background overlay - I just changed this value as a test from 60% to 20%
This is from my localhost but this is where you change these settings
Cheers Paul
Thanks for the very quick response! Your adjustment is perfect. (My problem was that I was trying to make the change in the module instead of in the template - now it makes sense to me.) Best regards, Charles
Yeah no worries - easy mistake 🙂
I made this mistake first time I saw this template
I'll mark this thread resolved now
Cheers mate
