Hi, guys, when i using the Features Intro Style 2 I found two issue, here is the link 1. too much bank between the title and sub title, not like the demo
i want to show you the link then i found another issue https://www.samfull.net/home.html
i want https://samfull.net/ as my home page, but i check it is not, as i used the rocketheme template before, that show something about, if you know tell me how to change it, thanks
the default homepage issue is solved
owen789 Hi
@media (min-width: 992px) .sections-wrap .section .section-title, .sections-wrap .t3-module .section-title, .sections-wrap .section .module-title, .sections-wrap .t3-module .module-title { margin: 0; } }
.t3-header.affix { z-index: 100; background: #fff; }
Thanks very much, Teitbite teitbite
this solved on PC, but the mobile seems not change
seems not change
you code i have added in custom.css, i think it works, as i found issue1 have solved on PC
looking forward your reply!
the issue 1 is solved, now i check the mobile display is OK, THANKS teitbite
owen789 Hi. Ok, great to hear that. Closing this thread in such case.
