While working on the Responsive 2 template, I've discovered the following issues with Zentools 2 module.
  • It does not play well in the tabs position when using the filter layout. I've yet to get it to to work by modifying any module options. No matter what I do it keeps overlapping with the grid 17 position.
  • There is missing documentation for some content elements. The lightbox setting has a feature to "Display video instead of image", however there's no indication where this video is sourced from; whether it be an embed code or a link. The documentation does not explain this and there's no field in the module settings to put a video link. I've tried putting it in a source article, but that didn't work either.
  • I've realized that I cannot have (thus far) the best of several features: I want to use the tabs position, a filter layout to filter tags, but each item expands like the expanding layout. This would be ideal if anyone knows how to get this to work, but you have to choose one or the other. The filtering feature is great, but I cannot get information about a thumbnail or a linkable video like I can with the expanding layout.
Question: Is Zentools 2 still supported and is there a plan for a version 3?
Please help/ advise.
