Sidebar display in the bottom of the page(position 😎 instead of left side(position A). Please have a look at the following screenshot.
ptstudio Hi Can you share the URL of page on which you have this issue? On submitted site there are only 2 products and both are showing fine http://prntscr.com/oadw4r
http://www.colorplus.tw/index.php/shop/birdy
ptstudio Hi You have to create a menu item for each category. Like for birdy category i published the birdy menu item again. Now the product under this category will open under this menu. This is correct view http://prntscr.com/oag5lm http://www.colorplus.tw/index.php/shop/birdy/bike/bikes-1-detail
If you go to the link: http://www.colorplus.tw/index.php/shop/birdy
You will see the menu item is still on the bottom position.
ptstudio Hi Kindly check it now. Regards
Thank you for saving my day!
