Two Content Side By Side CSS Positioning, Float And Alignment
Buraya Bak Herkul
Right Left And Lower Side Will Be Like The Picture Below
How do I do a coding to do the same Please help
medator Hi This template is based on Bootstrap 2. You need use span6 not col-md-6 Here : http://prntscr.com/ofjs6j Once you add span classes it will work fine.
How to Scroll to the Right Side
Buraya Bak WWW.HERKUL VÄ°NC
What you said worked but left mourning
I want to move all right Page Left Justified How to Center
medator Hi The content is fine http://prntscr.com/ogkkmo If you want to align the text in this, you can add style for text alignment http://prntscr.com/ogkl0s http://prntscr.com/ogkkwe
Thank you very much I've added to the title right now this topic can be closed
