Hello guys,
the module we placed on position Head-right is not shown on mobile device... Any idea how to solve this? It is not blocked for small devices on layout tab in template settings...
Thanks!
wolfguard Hi Kindly Edit fields in first post and submit a temp super user login for staf. as there is no other setting except layout to hide/show the module position http://prntscr.com/oozcx9 I will check the configuration on your site.
Ninja Hey pankaj. I edited the fields... Thank you.
wolfguard Hi I can see the head right module in mobile view http://prntscr.com/opbtsg Kindly re check.
Ninja Hello pankaj, this is the head-search position what is working... The Head-right is not seen on mobile, there should be a logo... But it does not show Head-right...
wolfguard Hi Kindly check it now. I removed hidden-xs from tpls/blocks/header.php file.
hidden-xs
It is working now, thanks a lot !
