I have set up a new Joomla installation. After that I installed the template Ja Mono without sample data. I also installed the Ja PAge Builder. Unfortunately this does not work. How can I change this?
Greetings
leseliese Hi,
Could you share the FTP account also? I will check this for you.
ok...its done
I can edit 'test' page of JA Builder now and publish it also, kindly check.
Hi, Unfortunately, it doesn't work. In another installation the PageBuilder works. Same provider, same browser etc. Details see private fields. The url called is completely different.
leseliese Could you clarify this issue in more details? how it doesn't work? because, I just edited the 'test' page in JA Builder > added a header block > publish the page and it's showing fine.
I made two videos. See details. That should show the differences well.
leseliese Try to clear cache & cookies on your browser as I still can edit that 'bla' page and add a hero block into that page: https://prnt.sc/oxgm5s
