Hello, the products of this category works fine in Spanish language, but all works bad with a catalan language. When you click in one product of thos category in catalan, they open a url that is not correct and all products go to the same url not correct.
If we use not friendly url, then works fine. I don't understand...
You can test it in this urls:
This, in spanish language runs nice
[https://www.acudam.com/es/ferreteria/bombillas]
This not runs nice:
https://www.acudam.com/ca/ferreteria-cat/bombetes
    alceste
    This depends on the menu item: https://www.acudam.com/ca/ferreteria-cat of Catalan language. You must find another word for this menu item as I guess it will be the same with Spanish menu 'ferreteria', however, Joomla doesn't allow 2 different menu items have the same alias.
    Hello, the tittles are different. Spanish is "Ferreteria" Catalan is "Ferreteria-cat". It seems the porblem is been solved after purged the expired cache in hosting. I hope the porblem not appears again... Thanks
