Hello, I was wondering if I could ask for some help understanding the footer positions / functions in the UBER template.
For instance, There are two modules sharing the same position, but somehow have another 'hidden' position between them which isn't showing up in the template layout.
I've been trying to understand this, but its still not making sense, and I can't find much on the forums or in the documentation about it.
I don't know how to edit this position, other than to modify the template's Language file, which is less than ideal.
Any help understanding would be very much appreciated.
Thank you for your time,
Todd
Aaack! Sorry about that, not sure how that happened. Your account has been re-activated. Try again? 🙂
As an update as well, I've managed to successfully remove the content in 'footer1', and am now in the process of building a jACM module to replace it, or possibly, several, stacked.
After working with the Footer types of the ACM a bit more, I'm starting to understand better how they're integrated into the template as well. 🙂
I think I've now answered my own question. loool.
Anyways, thank you! The footnav positions are arbitrary positions called from the footer ACM. Makes sense now.
As always, thank you for your help, but you can mark this one resolved now. 🙂
Todd
