Hello, good morning, I am using ja builder but when creating a page, the page created is not visible, when I want to edit them they are saved there.
isicmexico Hi You are using Home Layout that does not have Mainbody section this is why there is no content. I changed it to default http://prntscr.com/qei84u and you can see the page has content now. Kindly use default layout in a template style and assign that to builder pages.
I don't understand what you mean, how can I apply it for more pages?
isicmexico Hi open the Builder Menu items and apply default template style to those pages. Just example the current page you shared i changed its template style to default.
I have done what I mentioned but the header and footer no longer appear on the pages where I use JA Builder
isicmexico Hi I saw you are using JA Builder template style for the builder pages : http://prntscr.com/qg7rfo When you use the JA Builder template you must add header and footer block via Edit page : http://prntscr.com/qg7ron If you will use JA landscape template it will show the header and footer from JA landscape http://prntscr.com/qg7s25
in other templates, I do the same and everything is fine, I mean I use a page created completely with Ja Builder and the header and footer appear
isicmexico Hi JA Builder template is plain template and does not include header footer so it can be added via Builder. You have option in JA Builder to add Header and footer section. This is how it works with JA Builder template.
In other projects I have the page created in Ja Builder using the footer and template header, as is possible in other templates and not in this one?
isicmexico Hi As i said JA builder temple is built for builder only so you can use the header and footer from JA builder.. Kindly check edit page you will see the header and footer block section as i shared in previous posts.
I already learned what you told me, now how do I delete the title with image?
isicmexico Hi Its from JA Landscape template Masthead section It auto picks the title and show it on masthead section : http://prntscr.com/qip819
Kindly open a new thread on JA Landscape forum page as this topic is for builder and already resolved.
