Please see screenshot below.
For some reason my impressions counts have been cut in half. Can anyone give me any insights on to why this could be happening? Ever since October each day it appears only half the impressions are being counted as part of day shows an impression count and the rest of the day zero. Please help
https://www.screencast.com/t/qdRdyrio
    grossiweb
    Can you fix the login details for staff : http://prntscr.com/qk8xja
    So we can check the report for a single day, when you see the reports fro multiple days it show the compress version.
    Hi Pankaj
    Of course, the login is
    ... removed by mod
    Please let me know anything else you need.
    Just really looking why our impressions numbers are down 50% for no apparent reason as our traffic and page views are basically flat but our ad impressions cut in half
    Thanks,
    Stefano
      7 days later
      16 days later
      Hi Pankaj,
      The issue is we are trying to understand how impressions could fall in half when traffic and page views has remained consistent. Please help me find an answer, can you check if there is any new caching that is occuring or DNS related issue that might not be counting all the impressions?
      Please offer any advice or suggestions so we can resolve this matter.
      THanks in advance for all your help
        grossiweb
        Please submit details where you see the impression is less.
        Because the graph is will show on the impression level. If an ad is getting less impression it will count less in graph as well.
        11 days later
        Hi Pankaj,
        Sorry for the delay. Check the image here
        https://www.screencast.com/t/3vSgNS95
        Basically trying to figure out how we could drop our impressions in half when nothing has changed with site traffic or ad configurations. Could this be related to some sort of caching or DNS related problem?
        When I test, by reloading the page i see the impressions number going up so just truly baffled to what could be happening here and would love if you could help me find the cause of this problem.
          grossiweb
          Its not related to DNS. please make sure if users using adblockers that will be blocked,
          As u saw the impression are increasing fine, it might be traffic source that is down as it calculate the impression only if the page is loaded.
          If you are using server side cache you can try to disable that, however since you tested that impression are working its something related to traffic on your site.
