Another question : I tried to create a link in the main menu, leading to the "Courses category layout" of GURU light.
Unfortunately it doesn't work when you click on it -> It shows an error page "Call to undefined method guruHelper::displayPrice()".
Same when, instead of linking to the "Courses category layout", I try to link to a "Course Layout". Doesn't work ever : Call to a member function getView() on null.
Please see the images provided
Thanks in advance
    eglais
    I have not found any Guru subscription active on your account.
    Kindly Repost the topic on Guru forum with Guru pro membership. As per support policy only active GuruPro members can get support for Guru.
    I only have the light version, but still
    it should work out in the menu ?
      eglais
      Light version will not give same output for JA Sensie as it has very limited features and there limited support on this.
      You can edit fields in first post and submit site super user login for staff, I will have a look on it.
      Hello Pankaj,
      Thanks for your help.
      I will give you the super user access.
      Please see the fields in first post
        eglais
        Kindly check it now. I disable Guru Pro overrides in template
        /html/com_guru/guruprograms/view1.php" in template "ja_sensei".
        Thanks, your a champion ;-)
        Seems to work out.
        Bye
        Ninja locked the discussion.
