Hi Gavick Team, i have a problem with viewing article content. On main site intro text of any article displays correctly on every module, but when i click show more button i'm redirected into empty content, just like a mainbody position, where article should be shown, was turned off. Any suggestions?
problem with displaying article full content
lukasziwaszkiewicz
In the example screenshot i saw you added an iframe in which there is external URL not loading this is why its empty.
can you add some text and check again
Ninja
Genius! I forgot that I had previously created a module with external Google code that covered the content of the article. After disabling the module everything works as it should.
Thank you for help
lukasziwaszkiewicz
You are welcome!
Ninja locked the discussion.
