Hello, I am trying to use "news show pro gk5" to display 6 articles in 3 columns (2 for each column), in the configuration "article layout" (standard mode, position: section-1)
I use this configuration (attached capture)
But the result is the 6 articles in a single column (the module is deactivated)
