Please, I try to connect Premium JA builder with the same ID and password than my Joomlart account. But it doesn't work. Can you help me please ?
I thank you in advance. Regards
yvan01 Hi Can you Reset your JoomlArt account password and try the login again, avoid special character and make a test. Let me know if still there is issue.
Hi, When I try to change my password, in the "Your Current Password" field, a message "Current password incorrectly entered, please try again" appears. But this is the real password I use to log in to Joomlart first entry !
yvan01 Hi Did you Reset the password? Kindly reset it first and then try again with new password.
I am sorry but I don't know what it seems "reset" the password cause I don't see this option on my dashboard (see attached picture please).
yvan01 Hi Here is option https://www.joomlart.com/member/login?sendpass Set a new password and use that.
