Hi Guys
I have 2 module display questions.
Module joms-app-341 - JS video display - when there's only one video set to display it's very small as though there should be 2 - is there a way to fix that so the video is larger?
and 2nd question - joms-app--339 - I'm trying to make a side bar module sticky.
It's almost perfect except it's overflowing the bottom jomsocial boundary
and I'd like to change the module styling to remove the padding and the background just from that module
I'm not entirely sure how to do that.
you can see them both at https://www.parasportontario.ca/member-area
thanks in advance for any help
