I made the mistake of using an old template but I realized late that there are problems on mobile and above all the way to configure the various screens is laborious as well as often incomprehensible.
I am using tiris template for the idealtenda.it site. After several attempts, I eventually managed to give the iphone site a decent structure. But there are some things that I have not been able to do and others that I have not understood.
I need to insert flags for choosing languages on iphone.
The flags in the desktop version are new, compared to the address line, I would like them to remain on one line.
The images often at the top of the site remain cut in half and you can see the bottom bricks.
I don't know how to get the white box in the elements of the modules that I added.
Also I had to change the ecommerce system because with joomshopping you don't get to the end of the transaction, but you find out after doing a lot of work for nothing.
In my opinion you should put some alerts on the reduced functionality of the old templates in mobile.
Last thing: for mobile android etc. is it necessary to make an xml on purpose? How many formats do you need to create?
Piero
