Hi info5
It will require a bit customization on this. You can backup this file:
templates/ja_cityguide/html/com_content/article/default.php
Download + unzip attached file and copy to replace above file.
For the masthead section, you can go to masthead module and make sure that you don't assign it to menu item of these articles pages.
