For a new web-project we are using the ACM Module and ja_morgan as template. For the presentation of about 15+ event-rooms that can be booked, we are using the style-2 (Features-Intro block) ACM-module. 2 rows, every event-room is a default/added group. So far, so good.
Now the problem arises, when my client needs/wants to reorder the rooms. This is NOT possible. If i want to display ADDED group 9 on top, i have to manually exchange item 1 with item 9. as a result, all other rooms have to be modified too. This is a real letdown. The same problem is for the Testimonials block-type. If you have 10 testimonials you cannot simply reorder them with drag and drop or similar.
Can you please update the ACM-Module for ja_Morgan and implement a way that makes it possible to reorder these groups easily? Maybe a drag and drop function or an additional INPUT field where u can enter manually numbers from 1-15 to define the ordering of the items on the frontpage?
Somewhere else on this forum a user also had a similar problem.
You would make me and many others very happy! Maybe you can also jsut post a code-modification on how the ordering of the groups can be achieved.
i have attached a picture to show the problem.
i would be willing to pay 50€ if you cant make this for free.
thank you!
Joe
