I can not purchase GURU PRO, the site does not work. When I click on Buy it takes a lot and redirects me. I log in to GURU's purchase option and nothing works, I think you do not want to sell anything. Very bad the website. I'll buy the KING LMS
Hi Marco,
Currently ijoomla.com is down since we're going through the data migration process to new unified portal as mentioned in our blog post : https://www.joomlart.com/blog/new-unified-portal-is-live-must-read .
Guru Pro costs $297 as single product so I'd recommend that you purchase the Ultimate Developer package $299 at https://www.joomlart.com/ultimate-developer instead. This Ultimate Developer package gives access to Guru Pro as well as many other products. After you purchase the Ultimate Developer package, you will be able to download from our new unified portal.
In case you want Guru only, then use this direct link to purchase it : https://member.joomlart.com/signup?product=3
