wsol Hi
Apologies for the inconvience caused. Will share this with the JA Dev. team for redressal
In the meanwhile, You may kindly refer to installation manual for Box theme as the basic flow related to procedures at broader level as outlined in the specific documentation are the same although plugins installed will vary from theme to theme along with variance in widget customizations/configurations
You can kindly let us know if facing some relative issue precisely and we would assist with the same 🙂
