problem with quick installation, the installation process is not completed. How to solve?
    elanto751
    If the installation is stuck in the middle in post case the issue is due to low PHP values on your server.
    Kindly increase the max_execution value to 300
    and memory limits to 512M from Server PHP values and then try a fresh installation again.
    It will solve the problem.
