Menu Color Problem/ Other menu item related issues
- Edited
eileens
1) What I'd essentially like to do is to have a color scheme similar to palette 9, but switch the primary and secondary colors. I need red to be the primary color. But when I try to change the colors it gives me this error.
2) I am also having problems with the menu item I added (competitions) showing the drop down subitem.
3) And when I create a single article menu item, and I click on the menu link, it takes me to a blank page.
aman204 I provided the site link and login info.
https://www.ackcsc.org/2020national/administrator/
also, see menu on home page - when I hover on the item, the parent item goes white (see "competition" menu item)
Are you also able to check the server error log for this site?
It may list the problem
Paul
I will have to request it.
Just to underline all the problems you are seeing are settings that need to be tweaked but without the template saving successfully the site won't save any changes made
At the moment the settings are set to hide the content area at all widths so no article content will display but at the moment the template won't save as per above - so this is what we need to fix
paulus1031
I will have to request the memory limit increase and the server error logs. I don't have the ability to access. Do you think that is part of the problem?
I have lots of articles I transferred from another site, too. They are all published but I can't get any of them to show up. I can't get anything really, to work correctly. Feeling frustrated.
I have just installed an extension called akeeba backup and taken a copy of this site - apologies I should have asked first but really wanted to get on top of your problems
I am able to install and get the template to save - so at the moment it looks like a potential server problem and I'm hoping increasing the server memory will solve the problem
Cheers
Paul
- Edited
At the moment I am thinking increasing the memory is the solution - once the template is saving we can get your content to display
Cheers
Paul
I don't think you are doing anything wrong
Cheers
Paul
Okay; the php setting has been increased to 256mb. He said as far as the server logs, he looked but didn't see much in there.
- Edited
eileens Okay; the php setting has been increased to 256mb. He said as far as the server logs, he looked but didn't see much in there.
1) As apparently seen, The template settings for specific option are saving without exhibiting any error and the changes can be seen reflecting pursuant to increasing memory_session limit
2) The dropdown menu item under mentioned parent menu item can be seen. Ref: Screenshot
My articles are still not displaying on the main content area of everything except the home page, and my other menu items do not show on the menu. If I want to change the color of the entire menu to red, should I be doing that somewhere else?
