Hello, I have a little problem with the display of the side bar in this page if you can fix it for me and thank you. http://www.aidepharmacien.com/index.php/emploi-recrutement/job/9-nouveau-job-du-16-08-2020 In fact a function of (display: table) was introduced in this page in order to display information in the form of a table which disturbed the display of the banners in the sides. when I disable this works the page is displayed perfectly fine. Is there a solution to do without removing the display "table" ?
zoohayr Hi This issue is due to HTML errors in the article content, Please check the no. of opening and closing DIV or table must be same.
