Hello, I bought Jomsocial 4.7.7 pro version. I download Jomsocial, themes, templates and addons, and I installed the files.
In my site Joomla (in localhost) I used the template Ja social II.
In: components/Jomsocial/theme designer/color, it doesn't change with the: Flat, Column, Shadow and kikiriki themes. Same problem with other templates like Protostar (standard template for Joomla)
Thanks!
Help, problem teme and template
simoned87
If you are using a dedicated JomSocial template like JA Social ii already comes with a pre style it will make conflict with theme. As both are using own style classes. The theme designer will work with default JomSocial theme.
Let me know what exact change you applied and not working as it will work with default Joomla template fine. The theme designer option is only for JomSocial theme.
Hello Pankaj, thank you for the support.
I link any images to better explain what I mean.
I selected the colors
But nothing changes
I selected the default template Jomsocial how you wrote above
Like standard base I used Protostar, why i can modify Ja social II also inside it. But I want to make other changement.
O my god! the site is no online I forgot! sorry!
Now works.
Thank you very much Pankaj.
