Hello, I have today installed T4 framework and blank template on a J 3.9.22 development website and although watching the videos and reading the documentation I would appreciate some help. I have two issues 1. I have a slide show which is assigned to "Masthead" but does not show up 2. The menu is over to the left of the screen and I need it central. Some suggestions or pointers would be greatly appreciated this is a development site for http://www.westcountry-camping.co.uk/index.php which is built on T3 and what I am aiming at replicating
Thanks in advance Dennis
Hi Dennis,
Could you share the super admin account of your site? I will take a look at the layout settings and see what's wrong here.
Thanks for your response, can I Direct Message this information ?
dorsetjoomlart You can edit Fields in your first post so only Moderators can see:
OK done that,
dorsetjoomlart
The issue came from the layout settings in template only. In the Masthead section, you set to load 'masthead' element instead of 'masthead' module position.
I changed it for you and the slides are showing now.
OK Thanks very much for that. What about the menu position issue being on the left of the screen rather than centralised?
You set the 'Container' of Mainnav section to 'Fluid' so it showed on the left, I changed to 'Fix' and it's on center now.
Thanks very much for getting me started. 🙂
Dennis
dorsetjoomlart You're welcome! Let me know if you need any further help then.
