I like to keep the original look of the quickstart home page ie as the screenshot shows below .However, what I actually get is shown in the 2nd screenshot.
What can I do to get back the original quickstart layout ?
    Hi jamarrett
    I restored original module code as you can see now.
    Note first to edit it disable your default editor setting it to none because timymce editor strips html code
    Thank you
    Which template do I edit so that I can change the icons
    Are these special animated gifs from GK ?
    So if I have to change I need to replace them with the same size of another animated gif ?
      Hi jamarrett
      That icons are font-awesome icons and they are loaded trough a css file /templates/gk_cloudhost/css/font-awesome3.css
      HERE you can find a list of all icons available
      If you indeed want to upload and show your own icon then you will need to apply a custom css code to the file font-awesome3.css
      Let's say you want to change your image at the same place of the envelope icon then edit file at line 134
      .icon-envelope:before {
        content: "\f0e0";
      change that line in
        content: "url(image.jpg)";
      where url image.jpg will be the path for your own icon image
      Hope that helps
