Hi My problem is that the module does not work on mobile phones, I see the image and the image of the marker but it does not work. Any idea how to solve it?
I already uninstalled the module and reinstalled it
maperez Hi Can you set the default template to Protostar and check the module working. Sometimes its issue from 3rd party templates and extensions. Also share the URL of site if its not working with default Joomla template as well.
Same for me , I cannot press on the icons on a mobile phone and get anything to work:
https://terraintamer.under-development.info/stockists/europe
Odly it works when emulating via a web browser dev tools
ltempest Hi The post is pretty old can you make a separate thread so u can also submit site info. at the moment it looks normal on URL u added : http://prntscr.com/1utm07j
