Hi i was working with this template and realised that there's a section based menu at the top of the page. I've been trying to change the information on this menu but I've been unable to find it in the backend. i was wondering if you could provide me with some information on this issue please, thankyou
    mojatu i was wondering if you could provide me with some information on this issue please,
    Could you post a screenshot with details of the page where this is happening ?
    would be also possible for you to add other then your website url also a temp super user account for your backend ?
    So we can have a look at your settings for the page ?
    https://cl.ly/3y3R0p24250G
      Hi the menus we need to change are
      HOME
      OUR DAY
      OUR STORY
      BRIDESMAIDS / GROOMSMEN
      LOCATION / RSVP
      as per the image attached
        Hi mojatu
        Please edit your buildr - Wedding Home template from template manager then select the Menu tab
        And then click on the onepage tab
          When you edit the links inside the one page menu area as indicated by Pavit they will only display when a module is published in that position row
          Cheers
          Paul
          Thanks for your help pavit, with the information you provided i was able to change the one page menu, cheers.
          pavit locked the discussion.
