Hi there i wanted Publisher Pro installed and i get the following error message can you help me thanks
klosterfin Hi Can you please edit fields in first post so i can try to install it for you and check why this happened http://prntscr.com/w6u2d9
Ok, I did the login details
klosterfin Hi Kindly check it now, its due to the user ijoomla already exist on site and installation also adding the same user. http://prntscr.com/w71nz8
