We are using the Gavick CloudHost template and when we set the CSS override to enabled then go to Templates>CSS the overrides folder is not showing so we cannot add our custom CSS
Any help would be appreciated
Rich
Problem With Override Missing
Can anyone help with this as we can't get access to put our custom CSS styling on to our site
Rich
In case anyone else has this issue
Solved - needed to manually create an override.css folder
Rich
Glad to hear that you sorted it out!
saguaros locked the discussion.
