- Edited
First thanks for your great framework,
I use virtuemart and some of my products have some variations,
when a user select a variation, page updates with ajax,
in T4 ajax does not update correctly and after update you can not see new product,
if you press F5 to refresh the page, it will update correctly,
if i switch to T3 with current data and config, everything works great,
so i think it is a bug in T4 or something like it,
you con go to product address in Site url and under price, above Upgrade Storage, from select list choose another variation and see yourself
thanks
