Hello
I have a question. Do you know a way how users in the Jomsocial community can use their points to exchange currency and buy virtual things?
which, for example, user 1 can transfer 500 points to user 2.
What possibilities are there to do that? do you know a component / plugin that is compatible with Jomsocial or who can produce such a tool cheaply?
thank you for suggestions
greet Dany
    klosterfin
    We do not have own extension to sell the points. i found one here on JED as you need, Since its paid, i suggest you first get in touch with provider to check its working before buy.
